Pro pipe 2 into 1
    Any one running a v&h 2 into 1 pro pipe on their late model tourer?
    Ran one on my 2007 Street Bob!!!!!
  • killerchef
    killerchef
    got a mate that runs one on his 2012 rk. farkin loud !!
  • killerchef
    killerchef
    pretty sure just stage 1 pb. farking loud but cant give you any idea about whether worth the bucks or not. he is happy with it.
  • ozymax
    ozymax
    about to fire up a Drago's Dragula 2 : 1 looked to loud out of the box so getting a new baffle made tomorrow
  • HogBag
    HogBag
    I'm running a bassani road rage with a 4 inch supertrapp baffle 22 caps closed and it's loud but nothing like the stock road rage system's volume. With all honesty its been a pig of a pipe sorting out the 02 sensor bungs but hoppfully I might have it right this time around. The 2-1 give the best perfpromace from all my pipes on the road but what a fuck around sorting out the tunning side of a exhaust to keep her runnig sweet.
  • ozymax
    ozymax
    Pauly, the dragula fits up OK better than some but still a little stuffing around mostly with the mount at the transmission.
    Finish is very good, sounds a bit loud with the baffle I fitted which I would think would make the original baffle VERY LOUD. I have had this guy make 3 previous baffles for me and they all sounded ok so the volume this time is down to engine size mostly. On a stockish motor I think it would be OK but not legal.
    This pipe comes with bungs for both 12mm and 18mm O2 sensors and they are in the right spot, 12mm's are in original position and the 18's you can sit and remove while the pipe is on the bike.
    The floor boards need to be spaced out and a spacer and bolts are supplied although spacer is just that a simple spacer. I used some after market ones that match the board mount shape.
    Nice looking pipe as well. Notice any difference in the tq department
  • ozymax
    ozymax
    No idea mate today is the first time this motor has been out on the road
  • Adam
    Adam
    Nice looking pipe ozy. suits the lines of the bike nicely and I bet the performance is well worth it.
