pillion pegs
  • catman
    catman
    can muscle pillion pegs be fitted to a night rod special 2012 model?
    they look to be a more comfortable riding position and stop my missus leggs from cramping.
    regards greg
    You mean peg mounts. The left one definitely as there is no pipe that side on the NRS. might look weird as it is a muffler mount as well as a peg mount.
    The rhs one might interfere with the pipe mount. you would have to go to the bike shop and check/measure the difference.
    They are both the same frame and swingarm but obviously different muffler setup. I had a muscle 2 years ago.
    You could go with a full muscle exhaust setup, headers and all, and then they would fit.
  • catman
    catman
    Can t do it , I bought genuine peg ,brackets and exhaust brackets from a muscle and the won,t fit on the exhaust side. FUck.
    But   saw that vance and Hines make them for their 2 into 1 systems and am going to see if they can be bought separately .
