Online: Stuart
T1's Harley services!
  • Bushido
    Bushido
    Took my iron up to T1 (Terroristone), to have No plate mod, Old man suspension & Air Cleaner race tuner install & map! I live in Venus Bay Gippsland near Wilsons Prom so it is a fair drive 2 !/2 hrs. I saw a pic of the rear no plate bracket T1 made for his own iron and thought that it really cleaned it up. He has since done several more & I must say he just keeps getting better at doing this mod his looks great but mine is even cleaner. It was a fair way to drive so I decided to hold off & get some bits to have the oldman suspension mods, thought the harley suspension really sucked & coming off dirt bikes which is always the first mods you do! Ikons rear & Ikon front progressive springs with ricors & Dyna fork tubes. This mod has made a huge difference in the way the bike handles much more sure footed no diving under brakes & much more comfortable on these South Gippsland so called roads! The other mod T1 also installed was DK 587 Hi flow A/C which I ordered with Tank lift & coil relocation kit which I installed and S.E super tuner! I think this mod has given me at least 10-12 more ponies T1 installed a tune that he has for his bike that was Dynoed. Now I know one 883 will tune different from another 883 but this map is really good. All up the price was very good, I think if I had the bike to a dealer, just the tune probably would have been close to same price as T1 completed all 3 mods. T1 is currently trying to set up his own workshop to work mainly on Harleys at the moment he is only available weekends to do the work but with the amount of people on this forum we could probably have him available weekdays! So if you want any work done on your bikes & you are not capapble, message T1. The no plate mod alone is easily worth the 2 1/2 hr drive! Grant. T1's business is called AA Custom Cycles so lets support him in his endeavours!
  • Bushido
    Bushido
    Update: Took the bike out for a good run yesterday, really cannot believe the difference T1's tune upgrade has made! Before I had it done I was thinking of going to a 1200 upgrade maybe 12-18 mnths down the track but after yesterdays ride I really think now I probably wouldn't bother. The difference in the motor is huge. The slight popping on decel is gone & just runs so much smoother! And the suspension upgrade is fantastic, I used to feel the rim hit on even the smallest of driveway aprons no probs now I have full range travel & the plushness of the oldman suspension setup T1 completed!
