tab auto tuner
  • catman
    catman
    does anybody have a tab auto tuner on a v rod and are they any good?
    regards greg
    Been running one for a year or so on my 2010 Muscle, love it, replaced my SERT.
  • catman
    catman
    thanks for the reply allde.
    i have slip ons and the air cleaner mods done do i need anything else other than the tuner for it to work good.
    The TAB Auto tuner comes with it's own Harness, Read the instructions twice and shouldn't be a problem installing it.
    Just don't go bending any connector pins.
    Have the same set on mine, The bigger Air Box and the TAB Exaust system, you don't want the 2" baffles trust me after a while they really piss you off, the constant drone in the ears.
    Go the 1 3/4" Baffles, not so hard on the ears and the tones nice too, thats if your running the TAB Exhaust.
    Ps. Keep you standard Exhausts, they are the only ones that will pass a Noise Test...
    Best of Luck
  • catman
    catman
    Thanks again allde
    Where is a good place to buy the tuner ,I have seen them on eBay but was wondering if I can buy in Aust at a reasonable
    Price I would rather do that.
    Thanks
    Contact Details
    The home of VROD PERFORMANCE or TABPERFORMANCE AUSTRALIA is
    14 Joslyn Drive, RESEARCH, Victoria, 3095
    http://www.tabperformance.com.au/
    Email us at gb@tabperformance.com.au
    Direct Phone Contact is (03) 8640 4004 begin_of_the_skype_highlighting  (03) 8640 4004 FREE  end_of_the_skype_highlighting OR mobile: 0417 510 096 begin_of_the_skype_highlighting  0417 510 096 FREE  end_of_the_skype_highlighting
    Fax - (03) 9349 1161
