Seeking advice on a cam
  • Ando
    Ando
    mate throw in a set of Andrews 48s
  • Ando
    Ando
    if ya want your torque and power to come on more in the mid range to top and you are prepared to lift the heads and fit a .030" head gasket throw in the Andrews 57's
    I about to do this with a 96ci Softy
  • HogBag
    HogBag
    Nice light bike go with the 54h and hang on.
    The lifters may need replacing while your in there so do some home work on your cam change as you will need oil pump orings, spacer for the cam, lifters, quick fit pushrods, gaskets, timken bearings.
    Its worth the money as it will pick up a 20 to 30 HP gain dependent on cam choice.
  • newschool
    newschool
    Can only speak from my experience, fitted SE211 cams to my old 2009 FXDB with SE stage 1 AC and V&H 2in2 big radius pipes no other engine mods. Got 84hp on Bikecraft (Cairns) dyno tune. sounded tough and pulled well above 3000RPM
  • Jimmy The Human
    Jimmy The Human
    Chris I went 204's and it sounds angry. and got about the same result as Newschool... well Jimmy;s dyno dot reakoned 20% more grunt up in the 3,000rpm. 96B with SEPT Freedom pipes etc
    cheers Jimmy
  • Spero
    Spero
    Hey Chris,
    I've recently had a set of SE 255 cams fitted to my 2011 FXST. To best explain the change in power for me is to say it's more crisp, the sound is noticably deeper with a slight lope although my idle is set at 900 RPM which helps to eccentuate the lope. If you ride the majority of the time around 3000 RPM you will be happy with these cams.
  • Spero
    Spero
    Hey Chirs, I did consider the 254e but decided to go with the 255's as my mechanic (Frasers Fairy Meadow) had a customer that had changed from the 255's to the 254e & regretted doing so. I can't remeber the reason he gave for regretting the swap only that he preferred the 255's.
  • Blown66
    Blown66
    I have gone Crane Chris Rivas Rocket 574 cams for my 103 but they are not in yet as I want to put in the Fueling oil pump kit at the same time.
  • Spero
    Spero
    By lifters I take it you mean Pushrods?? Definitely adjustable mate, heaps more fucking around & expense to keep the solid ones! All up parts & labour cost me $1080 at Frasers Fairy  Meadow, they had a deal on at the time that saved me $200..
