Brake Pads
  • Peter
    Peter
    I bought a set of Lyndall pads and will fit them sometime soon, but what is the go as far as tools are concerned to undo the bolts holding the caliper on an 06 softy. I don't think a ring spanner is the right tool ?? Can anyone enlighten me??
  • Bobtail
    Bobtail
    Hi Peter,
    I used a10mm socket on the main caliper bolts and a good quality 1/4 AF ring spanner on the retaining pins. The ringy needs to be thin due to the recessed nature of the pin.
    Bt
  • Peter
    Peter
    Thanks Bobtail, I was gonna do the same thing but it looks to me like there might be a specialized tool for the job ??
  • Peter
    Peter
    Thanks all.
