Online: GGUser744
Steering Head Bearings
  • fusion
    fusion
    Just picked up me superglide from a full service and they said ....steering head bearings notchy....bike only has 38,800 k's......you will need to get them replaced next service....its  a 4 hour job and will set you back $700....does that sound right?
  • noundiesundy
    noundiesundy
    sounds like you couild buy yourself a good lift jack, a manual,the parts and a heap of slabs for that, with change and learn to do it yourself. Not much different to the old malvern star you'd pull down, respray and generally play with when you were a kid.Give it a crack and have a ball doing it,you've always got the guys here if you need advice.But i do understand sometimes the time may be a factor, but hey, here for a good time ,not a long time.
    Johnny
  • Colstah
    Colstah
    Yeah, it's not hard, but you'll probably need a special tool to remove the old bearings.
    I've changed mine, but if I could have got Chopaweeza to do it at $200.00 plus parts, I probably wouldn't have bothered..... (I have no connection to Chopaweeza whatsoever!)
    Don't suppose you'd pick up from SA for that price, Choppa?? :)
  • fusion
    fusion
    Thanks for the advice everyone....looks like I will be taking a ride up to North Richmond when the time comes.....thanks chaps...
    Yep....Do not stress too much about them as mine are notchy as well (original bearings on an 86 FXR)
    Just get to them at some point in time and you will be fine.
  • 06 Softail
    06 Softail
    Geez, that sounds a bit steep. I paid about $500, & that included hiding all the wires and cables inside my handlebars. This was not done at a Harley stealership either. I think they like to charge like wounded bulls. That's why I always try an independent wkshop.
