Online: Stuart
Changing pipes is a retune rquired?
  • CairnsFXDF
    CairnsFXDF
    Ok guys just trying to sort fact from fiction
    i rang a dealer who told me that if i change from my V&H 2-1 to a set of short shots then a retune is required. any useful input is greatly appreciated
    Cheers Dan
  • Underground
    Underground
    I believe they're looking at it from a 'blinkers on - canned map' way of thinking.
    Yes, they are thinking they would need to select a 'canned map' from the drop down menu in SEPST which would change it from 2-1...to 2 into 2...
    thats all.
    you can do this, and more by buying the cable and software yourself.
    (and no - i think you'd be ok, but I bet you will get some decel pop)
  • CairnsFXDF
    CairnsFXDF
    thanks mate i get decel popping and cracking now.
