Where do i get push rods from in oz
    Hi there everyone. I'm just wanting to know where to get some adjustable push rods here in oz if posible. For my 2012 Ultra, 103 stage IV engine as i'm doing some more mods, and am needing adjustables.
    My original choice to keep thing easy (yeah right) was to get some Crane pushrods #4-0021 but i cant find a supplier in oz.
    The other choices are S&S #93-5096.    Andrews #292288.   Feuling HP+ #4065.
    Are all of these quality items? Any horror stories from you blokes?
    I dont want the quickee or ez fit style as they are a lot heavier and i'm trying to keep the mass down if I can. And i don't want aluminium ones.
    Can anyone suggest which ones would be the most suitable out of the above and also if i can get them in oz if posible, or who in the states would be the go.
    I also need to get some new covers, Colony #2148-8. So i can adjust them when installed. I want to get them from the same place if i can. Any suggestions out there.
    I know there are heaps of US suppliers for the above items but i haven't purchased anything like this before.
    I just want a pain free and easy purchase, and not one where i have to send a credit card and bank statement to the supplier just to get a couple of items.
    Thanks lads. Hutch
    My only advice would be to steer clear of Aluminium ones (yes I know they are very light) as they have a rep for flexing under high lift, something you may be doing with a stage 4 setup.
    All three brands are good so its really up to what you can locate at a good price.
  • chopa
    chopa
    Try Rollies. They are a forum sponsor also
  • ozymax
    ozymax
    yep Rollies is an S&S agent / distributor. Some stuff from S&S they can't retail but will put you in touch with the nearest retail shop if necessary.
    S&S or Smith brothers are 2 good quality brands
  • Ando
    Ando
    Go to your local harley dealer and get some
    either there quick install or the SE taper adjustables, I have been running a set of SE tapered adjustables for over 50 000ks and used 10 diferent cam, they have been in an out more times than I can count never had an issue and I rate them better than the S&S quickies Ihave installed on a couple of different builds
    +1 ... Post a request to HArley Heaven in the Wanted to Buy section of the forum and see what prices you get back...they are competitive.
  • oneball
    oneball
    Hi all...Hutch,Greens at Wallsend would have them.
    Thanks to everyone who replied, I am armed with some new leads now that i can explore. Just waiting to get all the gear together, then i will take a week off and have some fun. Something like this.enlightened
    Fob in hand,
    Jack her up,
    Spanners out,
    Cut and gut.
    Clean and strip,
    Measure and fit,
    Dyno tune and holy shit.
    Hang on tight,
    Might take flight,
    Burn some rubber,
    Go get a bite.
    Start her up,
    Grip the bars,
    Twist the throttle,
    Aim for the stars!
    Well lads, that my veiw.cool
    Hey lads Bike all fixed. Didn't end up using some bits but i will keep them for another bike in future. Bike goes like ^^^^^^^^^^. haha
