New Member 2005 Softail shift issue?
  • WILD65
    WILD65
    Hi everyone just a quick one have noticed on occasion bike doesn't like to shift back to 1st whilst at idle. Will be in nuetral and upon slight release of clutch it will then engage 1st. While it isn't a big deal can be annoying at times. Any ideas how to rectify or is this a common issue.
    Thanks
  • beagle
    beagle
    Adjust the clutch, should be around 2 to 3mm clearance at the lever. Failing that, get a dealer or indy to adjust the inner clutch assembly for you..
  • WILD65
    WILD65
    Thanks Beagle will give it a try as i said just an annoying issue!
