Online: Soapbox2627
Change your fork oil in tourers
  • nobody
    nobody
    Hoggy
    What I normally do is drain all the fluid out,then flush the legs out with a bit of diesel fuel,to get a lot of the crud out and then refill.If you get a small piece of wire and stick it into the drain hole,you will probably find a semi solid mass of crud stuck to the fork leg wall.
    nobody
  • rooshooter
    rooshooter
    hey guys
              do ya hafta remove the forks from the bike completely , like the workshop manual says?
               or are there some shortcuts?
