Ceramic Coating
  • Ozi-VRod
    Ozi-VRod
    Can anyone recommend someone located between Coffs Harbour & Brisbane to ceramic coat the exhaust & heat shields to match a matt black 2012 Muscle
  • Ozi-VRod
    Ozi-VRod
    Has anyone dealt with Thermal Edge Coating in Brissy?
  • Superglide2012
    Superglide2012
    www.procoat.com.au
    awww.coating king.com.au
    Ones in Sydney the other Cardiff just out of Newcastle. Can't vouch for either as I've never had a need for ceramic coating.
  • Ozi-VRod
    Ozi-VRod
    Thanks Superglide
    In the absence of other local options, I have gone with Thermal Edge Coating & should get the parts back later this week.
    I saw some of their work & it looks good.
  • Ozi-VRod
    Ozi-VRod
    I can highly recommend Thermal Edge Coating in Brisbane.
    Great work - matched the colour of my ceramic black TAB pipes, prompt service & good price.
    Give Paul Rooks a call on 0738899298 if you need work done in Brissy.
