Milky oil in tranny
  • daggs95
    daggs95
    Been in cairns for a couple of months working,  done a fair bit of riding and got a fair bit of rain over the 2 months. Done a few thousand k's so i done my usual oil changes and discovered the oil in my tranny was milky, was wondering if anyone has had this problem before ?
  • carbon fibre
    carbon fibre
    Have seen it in a mates softy after a weeks wet riding on the east coast. Not too much to worry about really, change and ride on.
    Milky oil is normally caused by water/moisture so just change it out and your good to go. Typically caused by short trips that do not allow the oil to heat up enough to evaporate the moisture.
  • daggs95
    daggs95
    Not at the moment but i will be back in about 3 weeks, have some more work to do up there, but more to the point my bike is sitting at a mates place up there and i am getting a bit edgy not being on her.
  • CairnsFXDF
    CairnsFXDF
    i know how ya feel mate, I'm sittin at work and it's clouding up. give us a yell when yer back up
  • daggs95
    daggs95
    Cheers Tussuck, i changed it and all good i just wanted someone to ease my mind, i had a feeling it was condensation build up just wanted to understand why.
  • daggs95
    daggs95
    Too easy looking forward to it.
  • daggs95
    daggs95
    Thanks for easing my mind, stay safe.
