Online: GGUser744
streetbob floorboards
  • carl65
    carl65
    Hi wondering if anyone has put boards on their streetbob .
    im thinking of doing this and would like to get some feedback on what boards to get and wht the fit up is like
    cheers Carl
  • carbon fibre
    carbon fibre
    Switchback boards will bolt straight up, also check Chinashopbull's bike, he has done it already.
  • carl65
    carl65
    cheers carbon fibre will do
    Searth the forum for "streetbob slim" as there are some pics of it done
    The streetbob done in the "streetbob slim" post used boards out of the Harley accessories book. And not as quick and easy to change over on account of disconnecting the midmount controls behind the primary.
  • Sparra
    Sparra
    Some of the ways China does his photo's make it look like a painting...Very talented....
  • ezzyd2009
    ezzyd2009
    Mate , you can put a cheap set of mini floorboards on you bob for less than 100$. Got my from JP Cycles in the states and i popped em on. Sweet as mate. I can ride for long hours in total comfort now. The only thing you have to adjust is the brake lever height as well as the shift lever, and it takes a few minutes to do too, eeeeasssy peasssy. Will pst some pics of them soon, as well as the part number.
    Ezzyd
