Online: WideglidingNZ
engine removal
  • ozymax
    ozymax
    on a twincam is it necessary / adviseable to remove the primary housing to remove the engine?
    Manual says yes but that look a pretty big hole after the stator is removed to move things around in.
    Just trying to get orginised ahead of time.
    max
  • carbon fibre
    carbon fibre
    absolutley, can't get to the engine to gbox bolts without it GONE.
    on a evo yes makes it easier would think it to be better on a tc too get to transmission to engine case bolts ?
    beat me to it
  • ozymax
    ozymax
    well that fucks that idea. guess I need to buy a few screws for the primary to gear box then. may as well replace the seal while I am at it.
    does this shit ever end????????????????????????????????????????
    nope where suckers its a drug
  • RenrawRd
    RenrawRd
     There is a gasket kit you can get that includes new inner primary to crankcase bolts as well as a seals and gaskets etc.
  • ozymax
    ozymax
    got it all mate except the seal and bolts for primary to gear box. But then again there is bound to be some thing else I have forgotten to get in advance.
    Maybe one day I should read one of the manuals I got and not ask silly questions here
