Online: HD17, speedzter
legend air shocks
  • fazza10
    fazza10
     legend air shocks, how do they ride with 80 kg rider?
  • blueystar
    blueystar
    Male or female rider
  • fazza10
    fazza10
    male
    Funny
  • carbon fibre
    carbon fibre
    One hook, two fish lol
  • KB
    KB
    legend air shocks are a legend :-). I bought a pair for my ultra, I weight in about 90kg with gear and throw the misus on the back (80 kg) plus about 10-15 kng of tools etc. Doesn't even notice it! I'd say at that sort of load they are just settling in and not to stiff. Solo I'd say they can benefit from some increase in dampening (maybe) as about the only thing I would say. Backup is briliant, had a soloid fail and they posted one out no problem.
  • Big Steve
    Big Steve
    What Model?
    The "proper" shocks ride better than the soft ail ones.
    Got 8000km ob my legends and love them
    I'm heavier than 80kg but thats the whole point - They're adjustable.
    http://youtu.be/YpOEOzy2UUE
  • RATTY
    RATTY
    i Bought the air shocks for under the trike 1300 dollars and they hang to low didnt raise the bike only lower and rang them to see what options i have to make the height i needed no help was the answer when i pulled the unit down to make it work the way i needed there was a nut inside acting as a 10mm spacer i would like to say i was joking but pretty disgusted on the quality of these units and before i modified the unit i was scraping on speed humps all that for 1300 dollars id use any other companies product before these and there is my 2 cents worth
