Online: WideglidingNZ
03 dyna dropping cylinder under load
  • petromarko
    petromarko
     03 dyna 3.500 ks v&h slip ons .rang morgan n wacker and mech told me to try die grinding butterfly out of bottom pipe.???
  • Ando
    Ando
    its ya flux capacitor thats connected to hydromixer causing that
  • Retroman
    Mate you've got wrong info.
    Firstly is the bike a 2013 or a 2003 ? IMMENSE differences
    If it's a 2013 the mechanic is telling you to open the "Active exhaust" flapper valve.
    You don't need to grind it , just jam it open with a self tapping screw or a pop rivet. Cost ? Nothing but your time
    AND the flapper valve is in the TOP header just before the muffler , it has a cable going to it you can't miss it !
    I still think its the Flux Capacitor too...
  • markwoumla
    markwoumla
    Flux Capacitor connected to Hydromixer !!!!!!!!!!!!!!!!! !!!!!!!!
    What the hell is this ????????
    Picture Please  !!!!!!!!!        Are you blokes taking the piss !!!!!!!
    By the way if your going to put a screw in the Axtive Exhaust Valve to lock it in the open postion, from my experience,  you will have to disable the Actuator , otherwise the cable will be trying to pull back and forth when idleing and riding.   Best bet, take it to dealer and they will disable the system in the open postion  via the ECU.   If you have an advanced tuner, you may be able to disable with that .
  • rider
    rider
    Fuck sake you blokes, yous all know it could only be the flux capacitor and hydromixer if he was going back in time, he mentioned nothing about that.
    For that matter, he didn't say he was going into the future either, so assuming he is, maybe he should check the spark plugs, HT leads, Coils, or a sticky valve,,, in that order.
    Besides, the flux capacitor and hydromixer must be working OK for him to have posted here about something that happened in the past, and for him to have been in the future to post about it.
  • petromarko
    petromarko
    Sorry 2013 model.yeah I was just surprised to hear the head hd mechanic tell me to get the die grinder out.if you bought a new car that was 3500ks ols you would expect the dealer to fix issues.not happy at all.oh yeah btw the spokes are all rusting and they told me I would have no chance claiming that under a factory warranty..shitbox
    find another dealer
    and DEFINETLY find another Delaer as the one you talked to is full of chit!
