Online: beaglebasher
Shorter Jiffy Stand
  • 883n Harley Convert
    883n Harley Convert
    Hi guys,
    Anyone know where I can get or whether I can modify a jiffy stand to shorten it on a 98 Dyna Lowrider? I've taken th 13.5' shocks of the rear and replaced them with a 10.5' (looks awesome and rides reallyl well) but my stand is a little too long and I have to lean the bike to the right a little too much for my liking to get the stand down properly.  I will also be lowering the front in the coming days, just need to pick up fork oil to change the springs.
    Waz
  • ozymax
    ozymax
    what about bending it a little?
    Not sure what they are made from though
  • Colstah
    Colstah
    http://www.ebay.com.au/itm/Bahco-319-12-Hacksaw-Frame-/350620837668
    Just a thought ;)
    cant remember what the stand looks like on a dyna but I know for softails they make a angle wedge that goes between the stand and mount which is used for lower bikes or a lower stand
  • Deadwood
    Deadwood
    Bought a 1" shorter kick stand from J & P Cycles when I put 10.5" shocks on.
    883n Harley Convert
    Thanks gents, I spent sometime with a few beers in the garage this evening with a mate and (as you on the beers) think we've identified another issue. My stand is dragging along the road whenever I hit a bump, actually had two people in cars almost pull me over to let me know my stand was dragging and hanging way to close for comfort. I put it up on the lift tonight and it looks like the spring is fucked, she's a little stretched and isn't returning the stand to the correct position when I'm riding and it scrapes across the road, makes a little sound here and there but I reckon if I hit something it may be a little problematic.
    With regards to the standing issue, we installed the Burly front springs tonight and its almost up straight so with the current spring and the height issues definitely just time to buy a new stand.
    Waz
  • Deadwood
    Deadwood
    Just buy one and keep your original. When I split the sump open I put some 12" touring shock on my Dyna and the 1" shorter stand leaned the bike over too far so it was handy to have the original still.
    883n Harley Convert
    Thanks for the feedback guys, much appreciated!!
    Waz
