Online: beaglebasher
Please help me with decision on 58mm throttle body
    Do you need such a big TB on your 96 ?
    What is your engine spec ?
    do you need it ? I think you better get it going again first
  • HogBag
    HogBag
    I would buy the HPI throttle body. What exhaust are you considering because that can make or break your builds HP. The clutch will need a heavy spring and maybe a VPC depending on the torque.
  • Ando
    Ando
    with the HPI unit you can use any aircleaner with the s&s 58mm you have limited selection
