Online: beaglebasher
tts cam selector
  • Bakes68
    Bakes68
     Hi guys, just got my tts finally, have loaded base map and runs better and cooler, now i need some help with cam settings, i have read a lot on the tts for the last 6 months while i saved money to buy it, but im not sure about this one.i have a stock cam in 2007 softail and from what i have read settings fot the stock cam are 12 atdc and 30 abcd which equate to open 7 close 2, which is what i had read in a post a while ago, but going by the manual and the analyser it is saying to set at 4 open,(picture below).Any help would be appreciated as im not sure which is right.
  • Steve Cole
    Steve Cole
    The TTS is the only device that can truely measure what YOUR engine is really doing. Hilly has it correct and you setting should be 5. This is just why you really need to measure what your engine is doing to be able to set things properly.
  • Bakes68
    Bakes68
    Thanks hilly and steve, i thought manual was saying to set 1 before opening, after reading it again it is saying its permissible to set 1 before. Will set at 5. Thanks for the help
  • Bakes68
    Bakes68
    set the cam to 5, did a vtune run (taped my iphone to the bars as a display), generated a file, loaded that and bike is running great, better low down acceleration and running much cooler.
    thanks again guys
  • Bakes68
    Bakes68
    Download an app called idisplay, then download windows version on laptop, put your phone as personal hotspot and in your wireless connections on your laptop you can join the network of your phone, once you join network start i display on iphone and it will extend your laptop screen, then start datamaster program and move it onto your iphone screen, then you're good to go. Sounds like its complicated but easy once you've done it once, and secure phone properly as mine nearly fell off when tape moved. Hope that helps
  • Bakes68
    Bakes68
    Did you try its sparra?
  • Sparra
    Sparra
    No mate,I downloaded it onto my computer but they wanted money for the phone app...Only a few dollars but I decided against it...I have a remote monitor but it's a bit big and hard to see in the daylight but I will play around with making a sun shield for it...
    Cheers...Sparra
  • Bakes68
    Bakes68
    yeh it did cost me 4 bucks for the app, found the same with phone had to ride with hand over it most of the time to see, probably not the best idea, now i have knocked off my daughters small monitor cause phone was too small, will just have to work out how to mount it and make sun visor as well. ah its all good fun till her monitor falls off, then im in the shit
