Online: John.R
Cleaning the wheels on my Sportster
  • warbo
    warbo
    Hi guys,
    I have the cast alloy wheels on my Sportster and I'm wondering what the best way or product to use to keep them clean.  Don't want to go damaging them so thought I'd ask before I clean them for the first time.  Also any suggestions for what product to use on the chrome?  I have autosol that I used on my old bike but not sure it's the right thing for the new one?
    Thanks
    Warbo
  • Phillthy
    Phillthy
    Warbo, I use Autosol on the wheels and chrome. Still trying to find a product that will clean the cast mags though. Have tried alot of different things with varied success. The wheels are worst on the leading edge as the grime is forced into the casting. I think the best way is to get them chemically cleaned then powder coated clear, black or whatever colour you like.
  • kingchops
    kingchops
    Warbo,
    I have the cast wheels and they were getting pretty dull, normal cleaning with a sponge wasn't doing the trick so I started scrubbing them with a soft plastic brush, similar to what you'd get with a dustpan, it worked wonders. I just used the Harley tyre and wheel cleaner on them.
  • jim76
    jim76
    i use detergent (washing dishes stuff) used a brush the other day n seemed to bring them up preety good need a small brush my hand was getting stuck behind spocket. for the chorme i use window cleaner i gave the rear rim a wipe over with it as well
    I use C18 Truck Wash with my pressure washer , works great
