Online: beaglebasher
Blue TTS
  • Ando
    Ando
    2013 StreetBob, TTS, Vtuned this thing when we fitted Pipes and AC, all worked a treat.
    Went to up load a CAL with the new 107 build and get this problem ( in the pic), Using the same laptop and ran the Updater, Need some advise on this one, Steve if you can help out as want to get this working to get the CAL sorted in this new 107
    [URL=http://s307.photobucket.com/user/Ando1450/media/WP_002218_zpsbc1c0517.jpg.html][/URL]
  • Steve Cole
    Steve Cole
    Yes, that tells you in the message there to run the "TTS HD06 Firmware updater" (Green Icon on your PC). As we release updated programs for the PC side of things we may need to also update the firmware in the blue interface (HD06) to go along with the PC updates. Hook up you interface to the bike turn key and run switch on then run the HD06 Firmware updater. Should take about 30 seconds or so and you will be good to go again.
  • Ando
    Ando
    Thanks you pair I have it sorted, Had to go back to the updater and manually select HD06 FIRMWARE, then I found the icon and the rest is history
