Online: speedzter
Essential Tools
  • Frothychop
    Frothychop
     Hey guys & Cruizie,
    Just  had some pegs and grips delivered not much of mechanic and not a lot of quality tools. Wouldnt want to damage anything wondering what the toolkit should include to get me through the basics. Appreciate some tips :>)
  • Vogon
    Vogon
    Torx Spanners and soket wrenches
    Imperial Spanners
    Screwdrivers
    If you skimp on quality to save a few bucks, you will regret it in the long run.
    I would rather pay $70 for a hand full of spanners that I can rely on and look after, instead of paying $15 for ill fitting crap that I dont care for and loose..
    Steer away from vice grips, pliers and even cresent wrenches (shifters).. they are poor compromises for a proper spanner
    Exactly what Bonkerz said .
  • Frothychop
    Frothychop
    Thanks any suggestion on brands and where to get them. I'm on Sunny Coast Qld
  • Rocky2010
    Rocky2010
    Yep get the best tools you can buy as they will last you the rest of your life.
    Also there are several metric bolts on harley's these days as I have found with my Fatboy Lo.
  • Daggs
    Daggs
    I keep hearing over and over of people rounding out torx headed bolts. Yes make sure you buy quality gear but also make sure you use the right size bit for these bolts,
    The next size down from the proper size can fit but it's not the right fit. People using the wrong bit maybe why they are rounding them out but to me it's obvious that it's a bit loose and you need to go up a size....
    2 more other things
    1- get a torque wrench and torque fasteners to spec, problem is 1 wrench won't do the whole range of tensions, I have 3 that cover everything but I need them in my job, most owners wouldn't have them all. The 3/8" size that covers the medium range probably the best one to have if you only have one.
    2- loctite, get some and use the appropriate grade on each fastener
  • Frothychop
    Frothychop
     Thanks men off shopping tomorrow !
  • shingles
    shingles
    YOU can buy a set tourx head allen keys from HD shop if one around ,I bought set from gold coast HD shop wasn't even $20 and will do nut on footpegs adjust hand controls on bars
    and other places ,need set rings panners coz they fit lots on bike say 1/4 -1" I have open end and ring in the set I bought ,some metric as well if you ever want to do front brake pads
    there are some tricky sizes on our bikes .THE cheapest way 2 buy tools go 2 pawnbrokers always spanners an socket sets there and sometimes a lot of single spanners and wont
    cost the earth brands well if it says made in china not good or tiawan not good but made in japan tools ok make yourself familiar with brand names look on internet ask google what
    tools and names are ok don't rush and don't buy shit coz u will regret it and those funny tourqx head bolts are 12 sided so that's a must if u buyin spanners or sockets and u will need
    imperial allen keys of good quality SHINGLES SHIT HERE I AM GIVING ADVICE AND I CANT EVEN WORK OUT HOW TO WRITE PROPERLY  mate changing grips can be bit
    difficult u may have to spray lubricant up into grip as maybe glued 2 bar this is were u may have 2 look on internet you tube ask question how 2 remove grips on HD BARS AND u will find info and video usally da best 2 av a gander an watch first will pay off and give u heads up about removal hope u do this coz ive always used and thank god I did
  • Frothychop
    Frothychop
    Cheers Shingles grabbed some kinchrome torx and Allen keys a mid range set of ring spanners not sure the brand got them from Autoleaders about $30 for six from 1/4 up to bout inch. Used them to put on some Kuryakn pegs as mentioned gunna get a mate to help with grips but will take advice & watch vid 1st. Have snap on sissy bar going on for missus Get some picks up soon. Thanks for advice Shingles and other guys as well. cheers Frothy
  • shingles
    shingles
    firstly gaday mate now HD torx head bolts an nuts can be a little different 2 stuff you've bort beware of this especially in female type means u have 2 insert tool into torx bolt head sounds like its all about sex don't it but ive found a lot of tools not specifically made 4 HD wont be right as they have tapers in bolt head or something unusall mainly torx stuff
    especially allen key torx tool ive found out da foolish way ,tool seemed 2 fit ok then trying 2 loosen handcontrol bolts dam thing jumped over a spline and started burring all edges .IVE got plenty of tools been working on bikes and cars 43yrs but not many tools I have fit exactly right HD nuts an bolts seem 2 have a unique design a lot of small differences like tapering
    on bolts an nuts its the small bolts you have 2 watch if it doesn't loosen strate up beware before u apply more force coz will just strip torx splines an then u will hav to drill out ,I bought HD tools on internet from all over world ,some companies make tools just 4 HD SNAP ON does sometimes second hand sets available ,but tasks you doin will be pretty strate
    forward go get yourself some sockets say from 3/8"- 1" can be 3/8 drive also metric say 10mil- 20mil coz u will need if ya wana do brake pads ,2 put new pads in u can watch you tube or ask members and all shall be answeredSHINGLESan remember av a look at pawn shops bound 2 find cheaper tools u can never hav enough tools I hav 3 of everytin at least even if ya don't think u need that socket set at pawn shop if its imperial 1/2" grab it even if sizes r bigger than u think u need but only if sockets r 12 sided not hexagon type there not the
    best tool same wif ring spanner multi sided type aw make sure u watch you tube O if u take bars off but shouldn't don't ever let brake master cylinder thing that holds brake fluid hang upside down always keep master cyl upwards 2 roof ty up wif rope string or watever but keep it up don't let it hang upside down may cause prob with air bubble best 2 leave bars on
    when doin grips throttle side can be tricky make sure u observe whats goin on label cables with tape wen u take off throttle slide as theres 2 that's if u have 2 change slide maybe not ah well the joy of changing parts
  • Daggs
    Daggs
    The trouble people have with torx shouldn't happen.
    Just use the correct size Not the size down that fits but fits incorrectly!!
  • Frothychop
    Frothychop
     Thanks shingles Sounds like I've got plenty of buyin and learning to do
