Online: Soapbox2627, Hilly
Head Work - Melbourne
    Hi,
    I need someone to enlarge my intake valve seats for a 1.94" intake valve.  Any suggestions as to soemone reputable in the melbourne area?  I do not mind traveling to take them that extra distance though if they are not centrally located.
    Cheers...
    Hi,
    - Chambers are stock, but will be enlarged on the squish side to help unshroud the valves - not too much though. I'll then cc the chamber to make sure they are even.
    - I had assumed that you could just ream/grind the existing seat to support a larger diameter valve face, so have not purchased any new seats yet.
    - Nor have I purchased the valves (I wanted to send them in with the heads though) - I'm shopping around for some as we speak, so if you know of a local source then that would be good. I can get Ferrea from eBay in the USA but the post is a killer for some reason.
    - Stock intake manifold at this point in time.
    I am actually following a set of instructions from a book I picked up last year called "how to power tune Harley Davidson etc." by Des Hammill
    Am not looking for anything too fancy as the turbo takes care of most of the donkey work.
