Bike Lift - my version !
    I was partly inspired by Burnzi's home made lift, and it was going to be similar in design, but couldn't get hold of the right sized hydraulic jack.
    Burnzi's lift here : www.hdforums.com.au/Default.aspx
    I had access to some lengths of thick aluminium channnel, and fitted some 3/4 "Film faced" form ply that I bolted to the channel .
    I made my own version of a tilting wheel chock, and added adjustable jacks on the front. They are set up to bolt on casters if needed.
    I already had the Repco lift, so I thought I would make use of it until I get around to fitting a hydraulic scissor like Burnzi's.
    The rear stands just pivot down and are then bolted in place, and remove the bike lift. The stand is incredibly stable. Much more than the usual chinese lifts I've used.
    Now, time to get that engine pulled out again !!
  • Colstah
    Colstah
    Looks good, nice improv!!
  • chopa
    chopa
    Nice work well done
  • chopa
    chopa
    Nice work well done
  • GT 1200
    GT 1200
    That's a good idea using the lift the it can be moved out of the way.
  • clubbie
    clubbie
    Speedzter that is a great effort. I like the fact you can just pick it up and store vertically.
    Want a bike lift but running out of room in my garage with three bikes.... got me thinking.
    clubbie, that's the main reason I wanted to make my own. Not because of the cost.
    I wanted someting light that is easy to move, and then just stand upright to store out of the way when finished.
    You could just as easily use hardwood for the side rails instead of Aluminium.
  • SoftailSteve
    SoftailSteve
    well done
  • Ilovecruizin
    Ilovecruizin
    That's a great idea you are very creative! :)
  • 06 Softail
    06 Softail
    Great improvisation mate, I've got the exact same repco bike lift myself.  Best investment for the bike I have, makes life a hell of a lot easier working on the bike.  Very handy being able to lean it up against a wall when not in use too, I just remove the handle when finished.  One day I might use your idea to make a bike bench like yours.  Thanks for the pics.
