Online: Retroman, beaglebasher, speedzter
Rear Indicator on 08 Softail Custom Loose
  • johno1
    johno1
    Hello brains trust,
    The rear indicator on my bike is loose and I am not sure how to tighten it.
    I have taken the lens glass off to see if there is access to any bolt / screw but the globe housing seems to be sealed in and I'm not sure how it comes out.
    My other thought was that I have to tighten it where the wire enters from between the guard and the guard support but there is no room to get a spanner or screw driver in unless the rear guard is removed (seems to be a big job to take off a rear guard just to remove an indicator)
    My guess is someone out there may have replaced or had the same problem,  if so...........thankyou in advance.
    Johno
  • twincam88b
    twincam88b
    Some one will help you Johno, they usually do, that's the good thing about this forum.
  • johno1
    johno1
    Thanks Crash, now I know which way to start I will give it a bash during the week. (dare I say..........., another design flaw from HD)
    Johno
