Online: B0nes
I need new headers.
     Hey all. Does anyone use these or know anyone that does.
    http://www.jackpotmufflers.com/headpipes.htm
    Anyone have suggestions for performance headers that can used on my 103 ultra with SE slip ons available in Oz?
    Thanks. Hutch
  • Rick1310
    Rick1310
     I bought Fulsac for mine & I have had no issue that i can complain about even when a part broke after 4yrs they replaced it no question asked, they stand buy their product.
  • HogBag
    HogBag
    http://www.fullsac.com/x-pipe.html
    http://www.fuelmotousa.com/harley/exhaust.html
    http://www.sscycle.com/go-fast-showcase/motorcycle-mufflers/power-tune-duals/
    Or pick one of the many 2-1 exhausts
    Thanks for the info guys.
  • rider
    rider
    Thought about picking up a set of stock headers and removing the cat ?
    Plenty around that haven't been used.
    Yeah Rider i have, May end up doing my set. I was originally going to keep them with the orig muffs just in case of you-know-what. Hence toying with the "new headers" way. Cheers bloke.
  • HogBag
    HogBag
    I'm going to try a set of these from fleabay but I need to replace my oil pan first. These are cheap made in china headers for less then $300 deliverd.
    http://www.ebay.com.au/itm/230968435152?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
  • ozymax
    ozymax
    He has been making pipes for all sorts of bikes for ages, nothing wrong with them. Not sure of the stock header size but these are 43mm ID so maybe a bit better then stock headers if there the same size as stock all these particular headers are doing for you is removing the cat and valve.
    Usually his web site works out a little cheaper after you do the shipping and exchange rate at PayPal's rates
  • 113king
    113king
    G'day Hutch, I used Power Duals from V&H with Screaming Eagle slip-ons with knocked out baffles, headers went on last and noticed big difference. I like the crossover designs and beleve it helps with scavenging, just my opinion.
    Hi all, i have decided to do my headers and see how they go. Thanks for the advice.
