Online: obisteve
Moving Forward controls back - possible?
  • Rubber-rigid
    Rubber-rigid
    It's possible to alter/change anything on a harley - maybe you would prefer mid-mounts ? What bike do u have ?
  • terroristone
    terroristone
    Goto your nearest hd dealer can check out some of the other sporties that have mid mounts, sit and them and see if that's what feels better.
    T1
  • Rubber-rigid
    Rubber-rigid
    Yep - always a good way to go. I have mid mounts for a 2003 here if they're any good to you ? The type of seat, bars etc are all going to have an effect on which pegs suit u best. e.g. a short-reach seat may make all the difference. I took a 1200 with a Sundowner seat for a test ride a while ago - pushed me forward and lifted me up so much that the forwards felt like mid-mounts
  • Fe_Man
    Fe_Man
     Have seen these kits around, genuine HD part. Not sure if this is what your looking for but may be worth a look.
     Reduced Reach Forward Control Conversion Kit - Sportster
    Love the look and riding position you get with forward controls but not comfortable with the long stretch forward? This Forward Control Conversion Kit repositions the Original Equipment footpegs and foot controls up and back by 2", and positions the controls closer to the rider for added comfort and confidence. This kit provides additional leg clearance around the chassis and air cleaner, by moving the footpegs outward 1.5" (left) and 0.5" (right). The reduced reach places the rider's boot at the proper pivot point for improved leverage, while maintaining the "foot-forward" riding profile. This easy-to-install Conversion Kit includes heavy-duty steel mounts and shortened brake rod and reuses Original Equipment control supports and brake and shift levers, or can be personalized with your choice of custom lever styles.
    50700010
    Fits '04-later XL models equipped with forward controls.
  • wiv1
    wiv1
    Personally i prefer the forwards over mid mounts my back is fkd and found mids to aggrevate it more, i have a 72 as well
  • wiv1
    wiv1
    Double post
