Pillion and highway pegs
  • New Horizen
    New Horizen
    Hi all -  Ive searched the forums and am a little stuck if anyone knows the answer please shout. It could be the questions are too simple that no one asks them, and im showing everyone my noobiness :)
    1) How do I fit pillion pegs and mounts to an Iron 883n (2011)?
    2) Anyone know where I can purchase pillion pegs and highway pegs and their mounts for the 883n - at a cheaper cost than the stock HD sets?
    3) Does anyone know if a pillion seat for a FLSTN 2007, fit on the 883n?
    Thanks Guys/Girls,
    Ok i will have a bash.
    1, Follow the instructions you get with the new mount kit when you get it. (Thats what i would do if it was mine.)
    2, Limited market on them so i would guess that only H-D would sell them. Try E-bay 2nd hand.
    3, No, different in every way.
    Hope this helps.
  • New Horizen
    New Horizen
     Hi FLHuTChu,
    Thanks, how do I read 3 - No it does not fit in any way or No different it does fit?
    Sorry just clueless on my side - thank you for your help.
    Does not fit. Different mounts, curve, size. But if you have one, try it on as i might be wrong.
  • New Horizen
    New Horizen
    Thanks for your help, Ill go standard pillion seats and pegs from HD.
  • garlo
    garlo
    theres plenty of other options for front pegs... the problem is that you haven't given us an idea of where you are. I just fitted highway pegs to my 08 FXD for around $200. All brackets and bolts supplied.. (pegs were separate from mounts but included in the above price)
