Online: GGUser731, B0nes
2013 forward controls issue
  • Shane883
    Shane883
     I'm fitting my forward controls myself. Has been pretty easy so far. Now I come to the brake linkage. It seems I'm gonna have to remove my exhaust to get to it. Anyone had to do this before??
  • Bushido
    Bushido
    Hey Shane, just done the same job! No don't have to go that far! All I used was the 25T torx bit in a ring spanner took a little stuffing round but could be done easier with one of those ratchet type ringies! Cheers & good luck! Grant
  • terroristone
    terroristone
    As above, also using a heat gun to softer the loctite will help.
    T1
  • Rubber-rigid
    Rubber-rigid
    G'day Shane. Don't know what year bike yours is. I did it to a 2003 (standard headers) some while back - and while it can be done, found it easier to take em off. Don't know about the later models ?
  • Dermie
    Dermie
     Yeah think I had to loosen my exhaust to do mine too.
