Online: softfat
Handlebar width
  • NED1880
    NED1880
     Can anybody tell me what is the width if stock handlebars on a 93 fatboy ? I think they are 1" ?
    looking looking. . Ok found this on Narley choppers .com. But do you mean diameter of the bar? Yes they are 1".
     oem part no 56569-86.  Fits FLST 1987 thru 1997. width, 31.32”.  Height, 11.41”.  Centre width, 7.46”.  Pull back, 5.22”
    We have a handlebar chart in here in the reference section for the newer bikes FYI.
    http://www.hdforums.com.au/Default.aspx?tabid=71&forumid=12&postid=525545&view=topic
    hope this helps.
  • NED1880
    NED1880
    Awesome mate cheers, about to order some from the state's, just want the correct size.
