Online: Stuart, BigKangaroo
Sporty clutch adjustment
  • 666
    666
     how old is the clutch rik are you fully undoing the lever tension adjuster then readjust after main ajustment they do take a few times to get them right
     you back the cable off fully 1st then adjust downstairs 2nd then adj the cable last
  • terroristone
    terroristone
    http://youtu.be/invnrw3nj3U
    You can back off more to bring the release point closer to the bar.
    You could possibly have a broken spring plate in there also causing you not to be able to adjust it correctly
    T1
    P.s. Post in the sportster section next time, you'll get more responses.
  • terroristone
    terroristone
    Glad you got it sorted. Now look up sportster spring plate issues. Just something you need to be aware of.
    T1
