Online: Stuart, BigKangaroo
ACR and EITMS options
  • DYNA12
    DYNA12
    Hi, been out doing some smart tunes today with SEPST tuner. Not 100% sure what I am doing though interesting trying to work it out.
    Noticed in the Tuning setups that the ACR and EITMS are both disabled, should these be enabled? I am pretty sure the 2012 Wide Glide has the ACR's fitted, the base map the dealers put in have these disabled as well.
    Nick
  • Retroman
    EITMS is "parade mode" only for slow speed hot running.Engine Idle temperature management system
    I "disable" it on all the bikes I work on in Perth WA
    ACR's should be enabled only if the bike has Auto compression release fitted
    Bikes either have them ex- Factory or don't , VERY few folks ever fit them to their bikes
    What is not good is if the bike does have them and they are disabled in the Calibration
    Leads to a "hard start" syndrome , and I have seen that on a coupla bikes before now
  • DYNA12
    DYNA12
    Thanks Retroman, I will enable the ACR and leave the EITMS disabled. The manual for my bike says the ACR's are fitted to the 103 and larger engines.
    I havn't had any issues with starting tho.
  • Ando
    Ando
    I was playing with my uncles 2012 switchback and he had a HD download Cal and it had the ACR's disabled aswell
    he had is bike back a coupla times with hot starting issues and even a battery under warrenty, they told him there was nothing wrong and that the battery was a random thing
    dipshits just needed to turn on tha ACR's
  • DYNA12
    DYNA12
    Thanks Ando, I've just been out and reflashed the map with the ACR enabled.
