Online: Retroman
Noise in valve train after 54h cams
  • sophtayl
    sophtayl
    Hoggy,
    did you put adjustables back in ( I assume so)?
    They might need to be tweaked a little. We experienced this recently on an S&S motor also.
    mick
  • sophtayl
    sophtayl
    Hi Hoggy,
    each manufacturer are slightly different depending upon thread pitch etc, but yes follow the manufacturers destructions... This is always a good starting point.
    Keep us posted.
    Mick
  • nobody
    nobody
    Just another thought.If you fitted adjustable pushrods,did you also fit aftermarket tubes,have heard quite a few people chasing noises,and it turned out to be the pushrods contacting the inside of the tubes,as the pushrods sit on a slightly different angle.And some only touch at certain times due to different expansion and contraction rates between the differnt metals.
    nobody
