Oraca motors
  • gaza246
    gaza246
     Found these motor bulders http://www.rbracing-rsr.com/  they are taking about 350 and up 500HP motors. Yeah the 500hp motor would not be street . But really thinking hard about getting one!!
    Newly Redesigned Turbo Kits for 2006
    Note: For custom frames with 40 degree rake center mount turbos with center mounted intercoolers are available. For standard frames all turbos are left mount with right mounted intercoolers._N__Note:N______Note
    03-0007
    H-D Evo/TC88: Standard 2 Bolt Ports; 1 3/4" Primary tubes
    250 HP Blackbird: 2 Bar 15 psi
    $7,500.00
    03-0008
    H-D Evo/TC88: S&S 4 Bolt SA / B2 Ports; 2" Primary tubes
    $7,500.00
    03-0009
    H-D Evo/TC88: Standard 2 Bolt Ports; 2" Primary Tubes
    350 HP Pro Street Race: 3 Bar 30 psi
    $7,875.00
    03-0010
    H-D Evo/TC88: S&S 4 Bolt SA / B2 Ports; 2" Primary Tubes
    $7,875.00
    03-0011
    H-D Evo/TC88 (Specify Exhaust port Configuration); 2" Primary tubes
    500HP Pro Gas Intercooled Race: 30 psi
    Call for Quote
    03-0012
    H-D Evo Sportster: Standard 2 Bolt Ports; 1 3/4" Primary Tubes
    $7,500.00
    03-0013
    350 HP Blackbird: 3 Bar 30 psi
    $7,875.00
    01-0030
    Suggested installation 5 days/ Dyno
    Blackbird/Pro Street
    $2500.00
    03-0007
    H-D Evo Engines Standard 2 Bolt Ports; RSR Closed Loop EFI
    250 HP Blackbird: up to 2 Bar 15 psi
    $8895.00
    03-0008
    TC88: Standard 2 Bolt Ports; Delphi EFI
    $5895.00
    03-0011
    360 HP Pro Street: 3 Bar 30 psi
    $6595.00
    03-0012
    TC88: SA /B2 Ports; Delphi EFI
    $6595.00
    03-0009
    113 ORCA (EVO) SA / B2 Ports; RSR EFI
    $8895.00
    03-0010
    126 ORCA (TC88) SA / B2 Ports; RSR EFI
    $8895.00
    Mate.... That's for just the Turbo kit alone! They make awesome chit, but have priced themselves out of the market, plus they have a really chitty customer service record for their exhaust systems. Aerocharger turbos or Procharger supercharges are a far better option.
