89 Softail switch control wiring
  • butza
    butza
     Gday . Does anybody have a picture of the wiring for left and right switch gear connectors, or a photo so i can match it up with mine. Cheers
    I know my 90 fxst has white rectangle plugs that clip into the frame and than the hand control wiring plug into them, my new krafttech frame has the same as I made it the same as my oem bike if you search flebay us thay have oem style main wiring harness on there you mabe able to see them there
  • Burnzi
    Burnzi
    Have you tried the wiring diagram on here; Bottom of the page of Forums
    Reference Docs/how to guides
    84-99 Evo Manual Download
    www.hdforums.com.au/Default.aspx
  • Burnzi
    Burnzi
    Tuss I think thats the Northern Hemisphere version. The southern version is the right way up...........running. Hehehehehe
  • The Don
    The Don
     Pics of my 89 Heritage connectors, hope this helps.
