Online: softfat
Blisters on Fat Bob Front Tyre
  • ram6666
    ram6666
     I was cleaning my 2013 Fat Bob on the weekendand noticed that the front tyre is starting to blister. the bike has only done just over 3000 km.
    It's around 10mm across, 2mm high, on one of the centre tread blocks
    Has anyone else had this issue with the standard front tyre?
    thats not normal mate..take it straight back to the dealer and ask for a replacement (if it delaminates your going to be in serious chit)
  • ram6666
    ram6666
    Cheers Tussuck...off to Harley Heaven I go!
  • ozymax
    ozymax
    good luck.
  • ram6666
    ram6666
    People at Harley Heaven and HD were brilliant.
    They are replacing the tyre on Saturday.
  • fat103
    fat103
     The standard Dunlops are a shit tire/tyre but good to see them "HH" come to the party !!
    Just blew a fork seal on me 11 Fatbob @ 8500 ks so I'll see how I go!!
    Everything made in china these days and is poor quality.  SKF make seal kit wich is the bees knees but is a lot better than the original NOK seals.
    Sorry don't mean to hijack your post !!
