Stage one upgrade
  • Degs
    Degs
    Could some one tell me what i need to do with the exhaust valve cable and actuator when i go to  fit  a set of Vance and Hines short shots to the bike.Also what sought of tuner to fit .
  • Degs
    Degs
     At the moment I am just sussing out the best way to go with the upgrades, but can't wait to get started.I think that may be the best option for the exhaust actuator is just to remove the cable .what are people's thoughts on the screaming eagle pro  race tuner.
    I have a power vision and find it very easy to use, i would recommend them.
  • murf69
    murf69
    gday mate , ive got a 2006 with the 88ci motor & i have a similar set up to yours , ive got the screaming eagle breather & tuner with 211 screaming eagle cams , v&h short shots & i couldnt be happier with the bike . im in the process of extending the forks to 2" over with a 21 " front wheel & a set 0f 11" rear progressive shocks ...
