Fatbob front end dimension
ozymax
forks 48.94 mm OD
forks 252mm ctr - ctr as best I can measure
disc 161mm ctr - ctr would depend on disc mounting thickness and even wear on both sides
ozymax
good news mate, bound to be some modding required, What about the master cylinder?
ozymax
yep that should do it, what about the guard?
ozymax
ok sounds like you got it all covered. now get it done and post up the pics. lots of guys have asked about building twin disc fronts but can't recall to many actually doing it. good luck with it.
ozymax
go in to the nearest shop with a few used bikes for sale and take out your small tape measure and measure through the wheel guard mount to guard mount. When you find which bikes are correct or so close then you can choose the style from that model. may have to get a mount adapter made up to lower or raise it but that should be no problem.
If you at rollies then wackers is an easy visit
CairnsFXDF
Mate well done on the conversion, gotta love a guy who ain't afraid to do something themselves that is a bit left field
