Online: John.R
Replacing Seat Grommet
    My Seat Grommet on my 2010 Muscle tore right in the middle, which prevented the seat from locking down.
    Easy fix I tell myself, order a new one from HD Australia,  yeah right, HD won't sell you a grommet you need to purchase the whole seat @ $193 they can get F@#ked.
    So after a bit of research this is what you do to replace the grommet:
    1.     Purchase a Rubber Grommet from Burson's Auto Parts, Part Number A92 Mackay Bush Price $1.62.
    2.     Place the grommet on a bolt between two washers and nip up a frag.
    3.     You'll need a Lathe for this part, you need to turn a step in the Grommet 3mm wide 17mm Diameter 6mm in from the end.
    4.      Don't worry about the Internal Diameter, that's spot on.
    5.      The new Grommet has a Diameter of 25mm, that's fine for our purposes.
    6.      For the correct length I just used a real sharp stanley knife, if it's not neat don't worry, you can hide it within the seat.
    7.     Install Grommet, if you find it awkward to install you can remove a couple of mm from the Diameter that goes within the seat so as to make installing easier.
    8.     Smile you just saved your self $191.38
    And HD wonder why so many of their customers wont deal with them...
    Buy the seat, take it home, try it on, take it back because the grommet is missing, I bet they find one then.
