Indicators won't work.
  • Thomo1980
    Thomo1980
     G'day I have a '94 FXDL and indicators won't work, the left and right icon on the dash lights up and stays solid, however indicators don't flash. I've tried swapping out the two thermal flasher relays, however there's no change, also they don't tick like they did when the indicators did work. The bulbs are good too. So any ideas? I really hope it isn't the module as they aren't cheap?
    Any help would be great. Cheers, Thomo1980.
    Swapping relays would be my first guess, but look for pinched or broken wires, If you've fucked with the indicators wires recently you prolly haven't wired it up right.
  • Thomo1980
    Thomo1980
     Thanks fellas, I worked out the problem, brackets had to be attached to bike. Schoolboy error... Upper cutting self now.
