Did some Vtuning today
  • Ando
    Ando
    Did some Vtuning today for the first time in a long time
    I have my cruise area set at 13.9 in open loop, so any how after some Vtuning I thought I would go for a cruise with the AFR meter plugged into the rear cylinder and see what is actually
    a couple of pics cruising down the freeway at 90ks and 120ks you can see the speed and RPM and the AFR on the meter
    [URL=http://s307.photobucket.com/user/Ando1450/media/WP_001943_zps6ad2b68d.jpg.html][/URL]
    [URL=http://s307.photobucket.com/user/Ando1450/media/WP_001942_zpsbee00f8d.jpg.html][/URL]
    everything else looks pretty good  12.8 to 13 at WOT
    and between mid 13's and 13.9 everwhere else
  • markwoumla
    markwoumla
    Ando,
    Can you install the Innovate AFR meter on your bike and have it work like in your pics without having any particular tuner, or can it be used "stand alone" ?
    If so , can you give details how its hooked up etc .    I have a basic Cobra fuel module, (Fi2000) with the 3 dials and I've always wanted to find a easy way to check the AFR for piece of mind !!     Thanks Mate
  • Ando
    Ando
    Yeh mate its stand alone BUT if ya want to use it as well as ya O2 sensors ya need to have extra bungs put into ya exhaust
    it just needs power and the wide band sensor goes into your exhaust
  • Steve Cole
    Steve Cole
    The USB cable wiggle is about to come to an end Hilly. :)
    WiFi or bluetooth ?
  • buznuts
    buznuts
    Nice work guys, innovation (no pun Ando intended), at its finest. It is exactly what you guys are doing here that led to the car scene learning the black art of EFI tuning 20 years ago...
    Cheers- Ant
  • the_mongrel
    the_mongrel
    Man - I would love to do some more V-Tuning, but I had a similar issue with my laptop, and in one instance, shut down from the heat.
    There is a shop with a Dyno not far from me, I wonder if he would let me hire it and do my own V-Tuning?
  • the_mongrel
    the_mongrel
    Mongrel, if you look more into vtuning at one of the shops in Mitchell, let me know as ill go halves with you
