Online: brucefxdl
Voltage regulator
  • shovelhead1
    shovelhead1
     How ya goin guys , was out on a ride today got about 5 mins from home hit the blinker and the bike died , turned the head light off and just got goin again while still rolling long , got home checked the battery and only 10 volts .I checked to make sure voltage reg was bolted down ( earthed) was ok , pulled the reg plug out and she was cooked ,1pin stayed in the plug and other 1 in the engine , can you just order a 2 pin plug or am i up for a complete new unit , thanks Wal
