need help on sert error
  • lejj909
    lejj909
    I changed the cable of the sert dongle from serial port  to usb but then I can not program my ecm the error is bootloader is not loading quitting contact your HD dealer is my ecm need changing? any help will be appreciated please
  • lejj909
    lejj909
    Thanks Scotty I did that but now theres a new error it says the ecm does not allow programming contact your HD dealer. any thought? i tried to disalarmed by entering code hoping it might reset the ecm by doing that. but it doesnt
  • lejj909
    lejj909
    sert 476
    map 67
    176ae104-a1
  • lejj909
    lejj909
    I borrowed friend cd 477 loaded in tried and the error is the same now your ecm doesnt accept programming contact HD i tried recovery 1 and 2 but still the same looks like i'll be looking for some spending but this time not in mods but some waste thanks scotty if we can get that tech CD from the dealer and share it to all everyone will be happy it might be some just reseting then the dealer will charge you a lot
  • wayne.craft
    wayne.craft
    Hey guys where should I look for more info on tuning fuel injection this is my first FI bike and would like to know more about the systems, can you recomend any good books or web sites to read on the subject ???
  • lejj909
    lejj909
    My ecm fixes itself I borrowed Xp laptop and a usb to serial that works from friends and try to program ECM and it works Thanks a lot guys for your help
  • lejj909
    lejj909
    megamanual.com or get a decent tuner and start reading how to
