Online: Wanderer57
6th Gear Indicator
  • twincam88b
    twincam88b
    I'm sure this has been mentioned before, but I can't find the post.
    Coming home tonight from Adelaide I found that when I was riding along in 6th gear and the green light was showing, as soon as I accelerated the green light was going out. Decelerate and it would come back on again.
    Then when I was in Cruise Control and I would rap it on it would do the same and the cruise control light would go from green to orange.
    Reading the book it states that the cruise control will deactivate over 137kph, or if you increase your speed 16kph over your set speed. It seemed to be very sensitive and cut out at the same moment I lost the 6th gear indicator.
    Anyone can help with the 6th gear indicator problem????
    TC
  • Hoodaman
    Hoodaman
    I never stop learning from you Scotty...thanx again..
