Online: Soapbox2627
hard to find neutral when running??
  • Bourkie
    Bourkie
    Hi Guys
    Got an 87 Evo the box runs well but very hard to find neutral while idling is this a selector drum problem or forks or something else???
    They are always hard to notch into neutral. Having said that I just adjusted my clutch the other week and suddenly I can pull up at a set of lights and snip her into neutral no worries. Mind you it drags a little until warm, but a small price to pay.
    And make sure you haven't put too much oil in the gearbox coz that can make finding neutral hard.
  • Bourkie
    Bourkie
    thanks guys will rip the primary off in the morning and work my way through to ajusting the clutch from there with all the road works up this way it would be nice to have neutral
  • Bourkie
    Bourkie
    well I ajusted the primary and changed the oil then ajusted the clutch and changed the gear oil with a fully synth and she will slip into neutral while rolling to a stop but idling at a stop is a no go for neutral so it looks like I will be ripping the box out of the old girl
    thanks for the help guys it was all worth a try cheers
    if the bikes gearbox works fine whilst it riding no noise changes nice apart from hard to find neutral when stopped why pull it out these bikes are like tractors even the late
    twincams are hard to find neutral at times it will never be like a jap bike maybe learn to drop it in to neutral before you stop + 1 to what ever one else has said
  • Robert
    Robert
    Hey Bourkie
    Bonding shields
    Change the oil in the clutch for Mobil ATF is the oil for automatic transmissions in cars, to some extent, eliminate the problem
    Another common mistake is too high oil level in the clutch
    Sorry for my english
    Plus pulling the tranny is not going to fix your problem...I run harley primary oil with great success. ATF also works for some as its thinner
  • Robert
    Robert
    I've done 40 000 miles on Mobil ATF in the clutch, everything works very well :)
  • Bourkie
    Bourkie
    All fixed an old mate from Kentucky told be to put in a Baker selector drum just finished and took it for a run it changes better than any harley I have owned thanks guys
