Battery cover falling off
  • Dermie
    Dermie
     Today I almost lost my l/h side battery cover. I stopped at a set of lights & felt it up against the inside of my left leg just hanging on by the lower hook tab. Good job it did not come loose 15 min earlier when I was doing 100kph out on the open road or else I would be looking for a new one.
    So are there any good & of course easy tricks out there for attaching them with a safety wire or anything????
    HD had a recall on the Clips about 4 years ago, I have cable tie on the bottom slot of mine just in case
  • Nomada
    Nomada
    +1 on the zip tie top left as you look at it.
  • careyman
    careyman
    mines loose too...sound advice
  • Dermie
    Dermie
     Yeah that may be the way I will go.
    Wonder if thats why they make em black on most models, so that it is easy to sell replacements.
  • wiv1
    wiv1
    Good save, they are pretty flimsy
  • Nomada
    Nomada
    Surprised their not colour coded so they can charge more.
  • als1200
    als1200
    Yea, lost my chrome one on the Bruce hiway. Now zippy tied on.
  • Sprocket
    Sprocket
    Hi guys,
    I had the same problem with the original clips 3 years back
    The upgraded replacement ones are fantastic and trouble free.
    Sprocket
