2013 Fatbob and Saddlebags
  • grantiscool
    grantiscool
     Hey All,
    So i'll be picking up my brand new 2013 Fatbob in a few weeks and I'm planning on putting saddlebags on it.
    I use the shit outta the saddlebags I have installed on my little Hyosung and was just hoping some of you guys could shed some light on what you guys have found to be the best saddlebags.
    Are you guys able to give any reviews/pictures/advice on saddlebags suitable to use with a Fatbob?
    I use the detachable sissy bar with rack attached . Throw a gearsack bag over back rest when needed . My 2c worth .
  • superroo
    superroo
    google Bad&g bags in the states..great choices and good prices
  • Donster
    Donster
    These are from Edge Xtreme Sports (the States)
  • grantiscool
    grantiscool
    They detachable Donster?
    Look great btw!
  • Donster
    Donster
    yes these can be detached similar to the pillion rest and rack and are locked in place with a key. You nee to order the Edge mounting brackets with the bags
    good luck
  • Donster
    Donster
  • grantiscool
    grantiscool
    Thanks mate! Looks great.
  • JimD
    JimD
     are they the EDGE STD size model 110?
  • JimD
    JimD
  • Builder bob
    Builder bob
     They look fantastic. Mind asking how much llanded great looking bob btw
  • FXST11
    FXST11
    I got the same ( Edge) but bought from a Young guy from Gosford NSW. He imports quite a lot of stuff, and is good to deal with try him, I saved around $180. compared with importing or buying in Oz elsewhere
    Austsales Direct 0405 247 408 ( Matt ). I got onto him originally when buying a jacket & a leather Vest a few years ago.
    http://stores.ebay.com.au/AUSTSALES-DIRECT/Bags-Brackets-/_i.html?_fsub=6&_sid=75593750&_trksid=p4634.c0.m322 ( might have to copy & paste )
    or
    www.finnmoto.com.au
  • chriso
    chriso
    i got the detachable harley ones on my bob, fucken excellent but as Rodders said not cheap
  • jmac
    jmac
    Donster, was the indicator relocation kit needed for these? I have an '08 Bob.
  • beagle
    beagle
    Check the clearance on the standard mufflers before ya spend the cash. All the samples pictures shown have non stock exhaust systems which have more clearance. Just a thought.
  • Donster
    Donster
    No indicator relocation required. that is also one of the reasons I went this way because everything fits up nice without any mods
    good luck
  • Rapson
    Rapson
    I have found a set of saddlemen saddlebags but the mounting brackets are not quite right for my bike (2013 Fat Bob) so I am looking at these brackets, links below.
    Can you guys tell me if they will work with a detachable sissybar set up? Or do I need longer bolts from Harley?
    http://www.finnmoto.com.au/harley-davidson-quick-saddlebag-brackets/
    http://www.edgextremesports.com/store/bmy_search.php?prevbrand=&in_category=414&fitment_cat=1&fitment_type=2&brand=12&model=286&year=2013&displayprod=Y
  • pva68
    pva68
    I used Easy Brackets.  Simple, lockable, detachable and can attach pretty much any bag to the bracket.  Good quality and no need for any ugly hardware to be left on your bike when the bags are off.
    http://www.easybrackets.com/index.htm
