Warranty Question
  • Hambone
    Hambone
      Hi guys
    I want to mod the duel headlights on my 2013 Fat Bob to have them both come on ,on low and high beam,will this void warranty if a problem comes up with wiring or what ever.
  • Normthe1
    Normthe1
    Only for anything that goes wrong with the headlight and/or any possible wiring issues they can blame on you.
    I wouldn't worry about it, I did mine but take a tip off someone on their 3rd headlight due to stone damage. Instead of soldering the new headlight in, put crimp joins in so that if you need to put the old one in then its an easy switch...
  • Hambone
    Hambone
    Thanks for the reply ,I'm going to do it as the single light shits me.
