Dent is rear guard
  • Fry
    Fry
     Hi all,
    I looked at my bike & found 2 small dents in the guard after washing it the other day. I have seen other sportsters with dents in the same place so I guess it's from having a rear seat.
    Here is a photo of my rear guard. The dent is only small but I know it was there & it was getting at me. ( I do paintless dent removal for a living so I have a eye for this sort of thing.)
    sorry for the bad photo.
    Has any one else noticed this?
    P.s. If anyone has this dent or others I can remove it :)
  • glucky7
    glucky7
    can you remove it ??? you tell us your the one that removes dents for a living
  • terroristone
    terroristone
    While your at it Fry you might as well give some more details about yourself (where are you located and a contact number and do you have a shop or are you mobile?)
    T1
  • Fry
    Fry
    I'm in sydney. My work is mobile. www.motodent.com.au
    If any one needs dents done my number is 0449252626
